[ QUOTE ]
JonSidneyB said:
I have not read the whole thread but I have some questions.
How do you plan on recharging these things? Does the manufacturer have a source for chargers for these?
Are these 1.2 or 1.5 cells or are they higher.
[/ QUOTE ]
Here's a little info:
I use a constant current (vs. pulse) circuit on my Lilons. My 1982 home built kit has an 8 position D.I.P. switch..each successive click corresponding to: 1.5v >3v >4.5v >6v. >7.5v >9v. >12v. and >"double amperage"..
I have found that the #3 click on the D.I.P. switch (4.5v) is just about right for charging the 3.6 volt rating of a single Lilon type cell. When the built-in voltmeter needle on my unit gets to 4.5v, the adjusted voltage cut-off kicks in and terminates the charging.
Rates that I use:
#2032,2025,2016 >8-10mA
"AA" cell>200mA
-I do not yet have a specialized charger for the Lilons, but what I'm doing now has worked well for over 20 charge/discharge cycles now.
What I'm saying is that for every 3.6v Lilon cell you're trying to charge, a fairly ripple-free regulated 4.5 volt constant current (approx.200-500mA for 185/176 series) should work for you very nicely.
As has been said before, you should be very careful to not let the voltage go above 4.2-4.3v while charging so as not to damage the cells.
p.s.-highland sun, have you checked with the people in Alhambra (Batteryworldcenter) re: those AAA Lilons?
-above edited to give better advice, thanx to Doug S)
