aceo07
Quickbeam, LED Cool mention in the Dealer's forum that the tube is not big enough for some NIMH batteries? Can you tell us about the fit and which NIMH battery you used.
LED Cool said:ditto here about the batteries used.
i tried maha 2700mAh & Sanyo 2500mAh, both do not fit.
Sanyo's 2500 can be forced/pushed in with my thumb but to take it out, i had to unscrew the LED module and push out the battery from the front.
LED Cool
Quickbeam said:Just added the LOW mode runtime with alkaline- over 10 hours before 50%.
Right now I'm running the test on low for the Jetbeam Mk2, which is about 1/2 as bright as the LiteFlux, and uses PWM instead of a resistor, so the Jetbeam may be much longer...
Doug P.
chevrofreak said:The Fenix L1T runs just under 7 hours regulated on low with an alkaline at 2.4x the output, so it seems that even though this is dimmer like more people were asking for, it's just wasting that extra energy instead.
Stick a smoothing capacitor on it =)Solstice said:This may be true, but 10 hours+ is still a good runtime for a single AA alkaline. The resistor has the advantage of putting out a non-flickering beam that can sometimes be detected in a PWM light.
LED Cool said:attached to the tail switch is a circuit board with SMT part. The SMT part looks like a resistor. it has black printing with white lettering. the white letters read "3R3".
anyone knows what "3R3" means?
LED Cool
