Hi there,
since the old thread has gotten a little long I will repost my little review of the LiteFlux LF2 here and add some new things. It's my first review, so I hope that's ok...
First of all the LF2 seems to be a little less bright then the L0D-CE. (Just have a look at the picture.)
Built quality seems good as far as I can tell.
One thing I noticed is that there are about four full rotations left from the off position before the head comes of and that the LF2 actually is turned off by fastening the head, so you definitely will never loose the head of this flashlight!
The only real disadvantage I see is the length of the LF2 (it's just a little longer then the L0D-CE but in this case every millimeter counts)!
Programing at first was a pain in the a... , but you only have to do it once so that's ok. And the second time was much easier allready, so you definitely get used to it!
I personally don't miss the tail stand, on the contrary: The LF2 has two holes on either side, so if you want to wear it around the neck (if you need it a lot e.g. during camping hollidays) you can thread a band through both sides and the LF2 will hang straight down. Most lights will hang on one side only which looks somehow akward to me. (Puh, english is not my native language and such things are hard to describe. I hope that's ok...)
L0D-CE on the left, LF2 on the right, both @ max. brightness
(notice that the difference in brightness seems to be slightly exaggerated compared to what it looks like for the human eye)
One thing cought my attention when I took the photo in a dark room: For the first time I really noticed the flicker of the L0D (at low setting), especially when the L0D stood still and I looked around in the room. And it was surprisingly distracting!!!
The wooden box the LF2 comes in is also very nice! One way to make it even better was to add a hinge to it (instead of the upper half just being a cap for the lower one).
But that I'm begining to nit-pick is actually a good testimony for the LF2...
One very (!) small drawback would be that you can't switch directly to P2. The LF2 remains about half a second at P1 before it changes to P2 even if you turn the head as fast as possible from off to P2...
That's why I changed from [P1-high P2-low] to [P1-low P2-high].
The idea with two stages however is great, and at least with my light both settings are exactly one half turn away from each other and right in the middle position you can "simulate" a clicky!
Edit1: There seems to be a first look at the LF2 SSC P4 version here at CPF, and that new version seems to be a little shorter. Looks to me like about the length of the L0D-CE, and that would be really cool...
Edit2:
The longer I use the LF2, the more impressed I am! Great light (in my humble opinion)!
Oh, and as it looks like you really can get used to the user interface!
Edit3:
A little update:
In the meantime I got the 10440 lithium batteries and tried those with the LF2! Here are a few things I noticed:
The brightness a little more then doubles (compared to an energizer lithium AAA)! I measured that with a cheap lux meter.
Of course for the human eye that equals an increase in brightness of only a little more than 1.4 (logarithm estimated), which is still rather impressive!
And yes, that way the LF2 is brighter than the L0D-CE with normal AAA batteries!
There's about a 10% loss in brightness after 1 minute, so that could be better and could be worse...
You shouldn't run the LF2 at max. brightness much longer than 1 minute anyway, because it get's rather warm after that time!
I have tested the L0D-CE with 10440s, too (even though it's not designed for those batteries), and it is definitely brighter than the LF2 again.
I think I will order the LF2 P4 version, too, and give it a try.
With 10440s it should be impressively bright and only a little longer than the L0D-CE. It's Its floodier beam may not be as good to impress your friends but it could very well be more usable then the more narrow beams.
Just my humble opinion...
So to sum it all up:
What I did like:
+rather bright for an AAA light
+no flickering in low modes!
+over discharge protection for 1440s and very bright with those!
+two settings
+very nice two stage switch
+programmable
+regulated
+can be well worn around the neck
+nice beam shape
+comes in a nice wooden box, makes it great as a gift
What I didn't like:
-a little less bright than the L0D-CE
-a little longer than the L0D-CE
Edit2:
Edit3:
A little update:
What I did like:
+two settings
+programmable
+regulated
+nice beam shape
What I didn't like:
