Robocop
Mammoth Killer
I often check my stored batteries for problems and voltage in an attempt to use up all of my older stock first. Tonight I was checking all of my AA Lithium cells and found one that showed zero voltage...by zero I mean it actually read 0.00 on my meter. I believe this battery has never been used and stored with others from the same package for maybe 2 years. I know it was not a meter problem as it continued to read other batteries and each time it showed zero on this one battery.
Is it possible or even common for a lithium AA to simply run down to 0.00 Volts in storage? Do Lithium AA cells have some type of protection built in to completely shut down a cell if dropped or maybe develope some other problem? I have only seen this reading once with a cell designed to have a tripped circuit for low voltage cut off (protected rechargeable) and even my very dead normal cells will show some type of reading.
There is no outside damage to the cell and nothing leaking and it was stored in a box with other cells in a dry room. It is just weird to me and I have no problem with the other cells and plan to use them but again just wondering if it is normal for a lithium AA to suddenly go to zero volts with no signs of external problem.
Also I know it was pretty sudden as I test all my batteries every few months and know that this one cell showed at least a 1.7V charge a few months back. I am weird like that as I store all of my cells together by voltage with the higher ones being used after the lower voltage ones. This one cell was stored together with 6 other cells that all had at least 1.7V and that is how I know this one cell was normal a few months back.
