Lithium Battery specifications 16350?
Albert_
I have a device that uses a lithium rechargeable battery. After carefully taking it a apart, without magnification, I wrote down information from the battery and then put the device back together.
However I believe I must have misread a 6 (six) as a 0 (zero)
Wrote down what I could barely read without magnifying glasses
EVE10350 CX 3.7V 3.3 WH 900 MAH
01800208174114
After google search the only results are 16350 (not 10350).
Without taking the device apart again and verifying with a magnifying glass I'm assuming it's a lithium 16350 900 mAh 3.7V rechargeable battery.
The length appears to be approx. 1/2 the length of a 18650.
I'm looking around for a higher capacity which I think the maximum capacity of a 16350 is 2200 mAh.
I'm not able to find much information about the 16350, such as it's size and dimensions.
Google search becomes confused and shows results for a 18650, and not much about 16350.
peter yetman
North Norfolk UK
You'll get better results looking for 16340 - only 1mm shorter. 16 is the diameter 34 is the length and 0 denotes a round cell.
Also there is no way you'll find 2000mah in that size cell, maximum is 700mah or thereabouts at the moment, a lot of manufacturers fib about capacity.
I'm assuming you are looking for rechargeable lithium ion.
P
ChrisGarrett
Miami, Florida
Never have come across a 10350, or a 16350, but that doesn't mean that the ChiComs haven't made either.
See if an 18350 fits.
Chris
