I used to take pictures in the cold in Kansas. I put my camera in a bag afterwards when I brought it into the house to keep condensation from getting into it. I don't think this would hurt a flashlight but it might be something to consider with a cell phone. I think a cell phone should be kept in the pocket of an inner layer of clothing to help keep it warm.
The bag thing is so that the condensation forms INSIDE the bag, not on the camera. Most of the good cameras that people do this with are *somewhat* weather sealed, or have their charging ports up on the side of the body somewhere. If you were to try this with a phone, the phone would sit flat in the bottom of the bag, and condensation could dribble down the sides of the bag and ?possibly? make their way into a charge port?
I'd be more inclined to bed it in some rice in a bag while doing this....
You keep your cell phone deep under your layers when moving about, yeah. While *using* it... hard to do the same :)
@ Therrin.
Did you charge any cells below freezing? Never charge Li-ion cells below freezing, it can destroy them.
Secondly, some cells maybe have about 50% of their full capacity at around -10C, and even less at lower temperatures. Some battery electronics/circuits may have a temperature sensor that shut off your phone for example.
Well, I didn't charge any of my round LiXx cells out there, so that wasn't an issue. I just went to use that 26650 cell while I was out there, and it wouldn't work. (works now)
I *did* use my Limefuel to charge my phone several times, but that was usually in-doors w/heater or in my sleeping bag. After my phone froze I thawed it in my sleeping bag (erm... between my thighs actually :sssh:), before recharging it the next day.
Strangely enough, I have a new issue now....
I recently went on ANOTHER outdoor foray in Minnesota, out in the Fergus Falls area, and once again it was ~ -25*F while I was romping around outdoors. (I seem to have found a knack for finding the crappiest temps and then going outdoors to do things in them :confused:)
My SolarForce L2p w/ Thrunite XML dropin just up and died when I went to use it. Swapped 3 different 18650's in and out of it...no bueno.
Brought it home and rang out the switch, works fine...
Tested all the batteries, all fine...
Hooked up my external power supply and fed 4.2V to the dropin itself, no bueno...
Pulled the reflector off and lifted the insulator around the emitter; carefully, briefly touched the + and - pads and FLASH!!!!! ... blinded myself. :duh2: Score!
So I guess my driver died??? It had worked fine the day before, then temps dropped again and I went to use it that morning and just didn't work. I've had that dropin for about 3 years and never had any trouble with it at all. Windchill was somewhere in the -50*F's again that morning.
The cold is the ONLY thing I can attribute to that driver just up and dying on me. Unless, it just chose that moment to wear out?? :(
I'm working on disassembling the driver pillar to play Mortuary Tech on it, but I gotta go get some wicking braid tomorrow to get the pillar partition board out; then maybe I can figure out what failed.
