rgbphil
Hi all,
I was wondering if you could help out with a non-LED question.
I'm designing a small device for a client and they want to use a Motorola Razr battery type BR50 internally. Current draw is quite minimal, but the device is semi-sealed so replacable batteries aren't an option.
I've found a suitable chip, the Microchip MCP73863 to charge the battery off a USB connection but am having trouble trying to figure out the hot/cold thermistor values needed to set the trip points for this chip.
I've taken apart a BR50 battery, found the thermistor SMD, nominally 10kohm which is the only thing connected to the 4 pin connector on the device apart from the battery connections and what is obviously a one-wire data or other battery ID pin. There are a few other miscellaneous parts which I presume are under/over voltage protection mosfets and maybe a eeprom. The 10k chip is not connected to anything else except for the connection pin and the neg-ve battery lead, which led me to assume it's the thermal sensor.
When heating up I can see the thermistor change value, but only slightly. I took apart the battery, removed the chip and tested it seperately but even when stuck in the freezer or touched with a soldering iron it only changes value by about 200-300ohms. For the MCP7386x chips you need to have a hot/cold ratio of about 3-1 to set the trip points. I would've imagined that freezer+soldering iron would exercise the thermistor across it's range. I've found datasheets for similiar SMD thermistors, and they have a much greater range of change....so I'm puzzled.
Any links to data on the thermistors used in these battery packs or more detailed charging data for mobile phone batteries? Googling about I can only find thousands of sites trying to sell me batteries, nothing on design data.
Thanks
Phil
Thanks
Phil
