Long running and dim AA light?
jezzyp
S Yorks, England
I'm looking for a loooooooooooong running, dim AA or 2 x AA light.
I have a Fenix L2DCE Q5 which is a great light but too bright on low.I also have a modded 2 stage Fenix L1P which is around half as bright as the L2D on low that is a tad too bright for what I want.
Multi stage would be great.
As for budget, Fenix prices or less.
The reason I would like AA is I'm standardising my lights where possible and have invested in a lot of eneloops for other things so I can always pull them if in a grid down situation.
I'm OK with basic mods (putting a 2 stage in the L1P is about my level).
Oh yeah, most definitely a Nitecorp D-10. It's all I'm carrying these days and I have several of them around the house.
Jetbeam Jet-I Pro IBS is another good option.
I have this one: http://www.bugoutgearusa.com/jetipro.html
The minimum output is about 2 Lumen and the run time on minimum is about 45 hours on a NiMH or 50 hours on a 14500 Li-ion.
I also have this: http://www.bugoutgearusa.com/jetiproexv2.html
Also with a 2 Lumen minimum, the website lists run time on minimum as 50 hours, but I can't see it being that little a difference. This review: http://www.light-reviews.com/jetbeam_jet-i_pro_ex_v2/ shows 54 hours for minimum.
The fenix L1T V2.0 is 16L on low.... and has a warm/yellow tint at that setting that I find very easy on the eyes. Its not a Low-low output though, so 16L might still be too bright for what you need.
Another recommendation for the Nitecore D10. If you don't have one yet, get one! You won't regret it.
Gerber Infinity Ultra (probably not low enough on fresh cells, but it's the cheapest at ~$16 at CFR Lights)
Photon Proton Pro (~$42-47 at CFR Lights)
NiteCore D20
NiteCore D10
I'm a big fan of JetBeam, especially in the AA format, where the IBS interface gives you a 2 lumen low; powered by a 14500, that will net you 50+ hours.
But the current AA runtime champ is indeed the Nitecore D series. Its minimum output setting is somewhere under 1 lumen, and combined with its super-efficient circuitry, the D10 powered by just 1 AA Energizer Lithium will provide over six days of light.
Selfbuilt ran the 2xAA D20 on regular alkalines and got just over ten days (meaning you could add a few more days on the Energizer Lithiums :ooo:), see his blurb here: http://www.candlepowerforums.com/vb/showthread.php?t=210904
Proton Pro
Nitecore D10 or D20
Jetbeam IBS models
Liteflux LF5x
maybe a single 5mm LED 1 or 2 AA light
I have to agree about the Gerber Infinity Ultra. When I got one, I thought they were worthless. Now, I find uses for them because of the low level.
Also, you can use old batteries that you would ordinarily throw away, and still have a dim light.
One guy did a test using a new Duracell and he gave it up somewhere after 400 hrs.
A slightly more upscale alternative to the Gerber IU is the Peak Kilimanjaro. They will probably be willing to set it up for you at ultra low power if you want that.
Minimag running the SMJLED kit.
Not that dim but the runtime is nuts anyway!
Is dimness a requirement in it'self or is it a means to achieve really long runtime?
Both - dim and long runtime.
My 3 year old doesn't like the dark. At home we have a mains 0.6w led nightlight which is fine.
This is for holidays etc. Too bright - Like the fenix L2D CE and he gets up to play in the middle of the night!
