Hi there, I'm a long term lurker but this is only my second post (exciting stuff). I was wondering if you could help me with my search for a headlamp which is basically ungoogleable, but should be easy with human intelligence.
Basically, I'm a caver and like to have a backup headlamp. In recent times, since I've assured myself that my homemade lamp is utterly reliable (until recently, I also had a Pixa 3 helmet-mounted - a superb lamp, but rather heavy for a backup), this has been a Petzl e-lite around my neck. They're great little lights, but mine hasn't held up well to caving, and the switch is going so I'm on the search for a replacement, something a bit better in other departments as well.
What I would like is:
* ... a very low 'low' setting, on which the battery will last a very long time; several days ideally. I've been trapped by floods in a very deep cave before and whilst I was fine for batteries, I'd like to know I could have some light for a long time.
* Reasonable brightness on the max mode - for once, I'm not going after lumens here. Obviously more is better if the other conditions are met, but 50 would be more than enough, and even 15 would be probably be ok (an e-lite is 26 with a fresh cell, but drops quickly). My main lamp is durable and has a long battery life, so my backup is used mainly for underground camp, getting to and from caves in the dark, and total disastrous primary lamp failure.
* Very small. This will be worn around my neck (by the way, losing one's caving helmet (often with attached backups) is a far more common problem than being strangled by a elastic cord). The e-lite was lovely but I suspect what I end up with will be a little bigger. Ideally, something smaller than the Petzl Tikka line would be nice.
* Durable. Waterproof to an equivalent of about IPX7 would be ideal though in practice I'm seldom underwater for long in caves, so water resistant would be ok. Generally rugged build quality.
* Available on a website that is ideally in the UK, though EU would be fine and elsewhere... OK.
* Budget - variable. About £50 ish max ($80), although I expect many recommendations will be lower.
* I'm happy doing a host/drop-in solution but haven't seen any small headlamp hosts.
* Battery type - as long as it's small, all options are fine. I'm considering lithium button cells, CR123 / their rechargeable equivalent and perhaps a single 14500 as the upper limit of size. At the moment I'm thinking that CR123s may be a good compromise, though I do have a spare 14500...
* Beam type - fairly floody is better but it's not so important.
* A red LED might be nice, but it's by no means a deal breaker.
I'm sorry it's quite complicated, but I though this would be a good place to throw ideas around. So far, the ideas I've thought of are:
1. Just replace the e-lite, they're popular among cavers so maybe I just had bad luck with mine.
2. Princeton Tec Byte. Like the size and the red LED, don't generally like AAAs. Also have concerns about the durability.
3. Zebralight H31(w/f?). Great durability, runtime, light levels (high and v. low). But expensive (a little over the top end of my budget)
Thanks in advance for your help!
Ben
Ben
