tnuckels
Hello to all you flashers,
I recently purchased a Longbow Micra (Thanks Flavio) and now may be having problems with it. Realizing it was only quoted at 90 min (less according to some estimates) I have been happily using it for the past week or two, so have no idea how long it has been running on the current battery.
Suddenly it quit working reliably, or so I thought, mostly when pressing the twisty tailcap for short bursts of light. Thinking it might be a contact problem I cleaned everything on the battery and case, but to no avail. Next I tried bypassing the tailcap altogether by shorting from the batteries negative end to the case where the anodization is removed and got the same intermittent results. Remembering some previous discussion of problems with the Longbow involving initial startup on used batteries and short battery life, I swapped for some new CR123s. Voila! Now it works all the time, every time. I checked the old battery with my ohm meter and it was putting out between 2.1~2.3v, depending on how long it was in use just prior to pulling it to test.
My questions are:
Does anyone have more detail on the problems earlier mentioned (startup, short battery life)?
For those who own Longbows, how much juice is left in your old batteries when you have to swap?
If I have a problem I’ll seek a replacement light, but maybe this is this normal for this level of purchase.
Many thanks,
Todd
My questions are:
Many thanks,
Todd
