[ QUOTE ]
darkzero said:
IIRC the LP wouldn't drop into my Micra. Did you have to shave the tab any? Was it a pain to get it centered? Does it throw as far as the original optic? In your opinion, which is better?
[/ QUOTE ]
My LP drops right in, and basically centers itself when I screw down the bezel most of the time, as long as I make sure it's sitting flat before putting the bezel on. Helps to point it upward, and put the o-ring and lens on top of the optic, or "dump" it into place sideways. Otherwise the optic will fall out.
Very convenient compared to some of the lights I've tried it in.
The beams look similar size-wise up close on a wall, except that the Carclo(?) looks more like the center of an NX05 beam, with a round spot, surrounded by a star. The LP looks a little different than it does in my KL1, I guess because of the spacing, with a perhaps slightly larger spot, surrounded by a square of light. My perception is that the LP lets more light through. With the LP, it illuminates a larger area just as brightly, so I prefer it over the factory optic (I had to switch optics back and forth, and run outside a couple of time in the midst of typing this, to keep things straight).
I really like this light, but would much prefer something with some spill like an NX05.
