OK, I'm in the middle of moving a couple towns over right now, but I just caught up to this thread...
I hope I don't miss any questions, but here goes...
Micra is fully regulated, allows 2 hours (I've tested it as well) of runtime with no noticable dimming. When it falls out of regulation, there is a noticable difference, but it puts out usable light for another 30 minutes or so
The mini is only partially regulated. There was a question as to why it said "optional". It's not an option, but there is a regulated version of the Mini due out in the next quarter.
The Booster head IS a 30mm optic and gives a better throw they are available very soon (days, not weeks)
There is a 5W upgrade for the Mini ONLY. The upgrade will consist of a light engine that just replaces the light engine in the Mini. A 5W version is due out in the near future, the working name for it is Max.
All LongBows can operate in a CANDLE MODE by removing the head assy. I have found that it's not really necessary if you are in a room with a 6-10' ceiling. The LongBow may be suspended from the high point in a tent with the included lanyard with the head removed for a very nice, even light.
There were some tests done by a testing company called PSB that is afiliated with UL and CE. All versions of the LongBows are waterproof to 250' (not a typo). They also did a drop-test with the light in the ON position and found that the light would still function (also with no fragmentation) when dropped from a height of 20m (yes, 60').
For those wishing to "mod" a bit:
The McFlood reflector fits quite nicely in the LongBows. My guess is that if you were to modify the reflector, or polish one, it would be a very nice.
I've messed with NX-01, NX-05, Fraen LP, Fraen 30°, and a couple other optics I can't discuss. The stock optic gives the most throw and best output, but the NX-05 comes in at a close second although it does compromise the 250' waterproofness.
BATTERIES:
The Micra will run on a rechargable 123 (R-123 = 3.5V or 4.2V) and has been tested by the factory as well. If you are using a modified charger that will charge to the full 4.2V, it will work as well. The LED will be in direct drive until the voltage drops down to the point where Vin is less than Vout on the converter. At this point, the output will be regulated just like with a normal 123 cell. I have not done a runtime test yet, as I haven't had time to modify my charger to go to the 4.2V, but I will do a run with the 3.5V charged R-123 I've got to get an idea of runtime once it's started regulation. Maybe KJ or Roy are already working on this?
The Mini will run from the Pila 168s (3.7V) with no issues. The brightness is less, but I got usable light from my Mini for well over 4 hours on a 168s. That being said, a regulated Mini may get some serious runtime.
The factory tested the R-123's in the Mini (2xR-123 = 7V or 8.4V). Their response was that it's "not recommended". They commented that the head got VERY hot and overdrove the LED too hard. They also commented that it could quite possibly damage the circuit as well.
SO, I hope there's nothing I've missed. I hope to be on the forums a little more soon although I've got a little flashaholic on the way in a matter of a couple weeks or so.
EDIT: clarified voltages on R-123 and Pila 168s
