Looking for a first serious flashlight under $200
NickAnzo
Hi guys.
I am looking for a flashlight with a good amount of flood for under 200. This would be my first flashlight so any guidance that you can give would be greatly appreciated.
I plan on using this flashlight for walking on a trail in a forest with lots of trees. Since this is my first serious flashlight, some versatility would be nice but not necessary.
The reason I think flood would be more useful than throw is because I don’t think that I would able to see more than 100 yards away with the trees blocking the way. Additionally I would prefer to be able to visualize my more immediate surroundings. I'm not sure what information would be required to aid you in making a recommendation so if you have any more questions I can expand upon that.
After doing a good bit of research I found that I really like the TK45. However, it seemed like the threads in which this flashlight was recommended were a few years old. I was wondering if any flashlights have come out recently within this price range that would exceed the performance of the TK45 for my specific needs. I saw some videos on the TM26 and I am in awe. However, without knowing if a cheaper light will meet my needs, it is hard for me to justify spending $300 on a flashlight.
Thanks for the help!
==================Flashlight Recommendation Checklist================
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
__X__This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____I don't know yet
____Up to $25.
____Up to $50.
____Up to $100.
__X__Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
__X__I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
____SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
__X__I don’t know/I don't care.
5) Emitter/Light source:
__X__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
__X__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
__X__I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
__X__I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
__X__I don't care
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
__X__I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
__X__Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
__X__Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
__X__Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends
I am not really sure what category will really be best for my specific needs
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
__X__50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
____150+ yards (I am searching from a helicopter)
____30-60 minutes (I have plenty of batteries just ready to be changed)
__X__90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Not Important (A “night-stand” light).
__X__Slightly Important (Walks around the neighborhood).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don’t know.
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today’s high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
__X__I don't care.
____I don’t know.
____A simple on-off with only one output level is fine for me.
__X__I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ---...--- emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don’t care.
____I don’t know.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
__X__I don’t care.
____I don’t know.
15) Water resistance
____None needed
__X__IPX4 (Splash resistant)
____IPX7 (Waterproof to 1 meter/30min)
____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
__X__In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_________________________________________ ____
____“Hybrid” light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
It's a lotta light for a beginner and you've got the whole Li-Ion thing, so throw at least another $60-$70 into the equation for a decent Xtar charger and four Panasonic 3400s and another $40 for a spare quad of protected Panasonic 3400mAh cells.
Chris
Are you sure you want to go with lithium-ion batteries for your first nice light? A light that uses AA's will save you money and still be plenty bright enough for walks in a forest. Plus, it won't suddenly cut out and leave you in the dark, like a lithium ion will do when the protection circuit is triggered.
Something like a 4sevens Quark QP2A-X or QT2A-X, and a set of NiMH Eneloop AA's plus wall charger will come in under $100. Nice floody beam, with modes from 0.3 lumens up to over 350 lumens.
Sunwayman V11R. It's not big or massively bright...but with the adapter it can run AAs in any format including 14500 Li-Ion cells. With those it really is bright, 350 lumens approximately...just comparing it to another full sized light. It's pocket-sized so you can take it just about anywhere. The variable output has a wide range too and the lowest setting is low enough to look directly into the reflector without blinking or squinting.
I suggest a headlamp. I hate walking with a handheld flashlight. We are designed to swing our arm when we walk, so the light goes up trail, down trail, up, down.......
A headlamp is pretty mutch "gyro'ed" when you walk, just like the barrel of a abraham tanks :)
I think the zebralights are one of the most versatile light you can get. It's mutch more than just a headlamp :)
+1 on the Zebralights. Suggest for flashlight, SC600 -1100 lumens on high for 2 hours on a single 18650 or the H600 for the headlamp- 1090 lumens on high for 2 hrs, same 18650. The only issue will be getting one, as stock has been sketchy. Do a search on this forum for reviews of the Sc600 MKII L2, which is the latest model. You can also check out zebralights' website for information about the lights, but would suggest you start doing some research on this forum and youtube, I would suggest goinggear.com youtube channel as he has a lot of videos of flashlights, to give you some idea.
