Looking for a new EDC flashlight - Checklist inside
Helion
Thanks ahead of time for any advice you can give. The market has changed so much since the last time I looked for a light that I feel a bit lost. Just having a shortlist of good models or manufacturers to look into on my own would be a big help.
I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
I'd might be willing to pay up to $100 but would preferably less than $50.
3) Format:
Flashlight.
4) Flashlight-specific format/size:
Every day carry small (2-4 inches).
Every day carry medium (4-7 inches).
5) Emitter/Light source:
LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
I would consider getting a light that is pieced together but do not prefer this option.
7) What battery type do you want to use?
A light capable of using lithium primary or rechargeable batteries in AA form factor would be nice but I also want to be able to use cheap AA alkalines if I'm in a pinch.
8) How much genuine out the front (OTF) light do you want/need?
I want to navigate a dark room or read a map (0-10 lumens).
I want to walk around an unlit rural area (50-150 lumens).
I want to illuminate my entire backyard or a campsite (150-300 lumens).
Variable output with good usability for the controls is a must for me.
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
Less than 1 yard/meter (reading, other close work) - Not common for me but nice to have.
Less than 5 yards/meters (looking for something inside a dark shed/garage/basement) - About half of my flashlight use.
5-20 yards/meters (check out a noise in the backyard) - Roughly the other half of my use.
30-50 yards/meters (I have a big backyard) - Not necessary but nice if I can get it.
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
30-60 minutes (I have plenty of batteries just ready to be changed)
90-120 minutes (Runtime is moderately important, but still not critical)
The higher end is preferable but I don't mind changing batteries more often when using standard AAs.
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
Very important, I like my tools to be sturdy and to last.
12) Switch Type and location (choose all that apply):
I want a tail switch for turning the light on and off and I like momentary on. I understand that forward clickly is good for that but also that those switch types don't generally allow for standing the light on end, which is something I want to do.
I'm interested to hear what my options are with this.
2 levels is acceptable but at least 3 would be prefered. Infinitely variable looks cool but is not necessary. Programmable isn't needed as long as presets are decent but would be fine to have.
As for controls. I don't like cycling through modes or brightness settings using the main on/off switch and have been dissatisfied with the usability of button based selectors on the side of the light. Selector rings look interesting and easy to work with although I've never used one.
I don't need strobe mode, SOS, or beacon modes. I won't be using them and they seem to complicate the controls.
14)Material/Finish/Coating
No platic but beyond that I don't care much. As long as the light is durable, can take a drop, and won't corrode if the finish is scratched I'm happy.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
A light that doesn't roll when laid on is side would be nice but a clip or lanyard can help with that. Having the ability to stand the light on its buttcap would be nice. I like being able to tie a wrist strap to my lights and a clip that can be put on or removed would be nice for experimenting with different ways of carrying.
IMHO, this is one of your best choices:
I have one of these. Mine has the XP-G R5 emitter, which I highly recommend. But these newer emitters are very good too. Just pay attention to how much throw versus flood you want. An XM-L emitter is typically floodier. My R5 is the perfect balance of flood and throw (for me).
Good luck
Shiningbeam also has some nice lights at a lower price. Fenix's E series is also nice.
There are many lights under $100 and the CPF marketplace could also work if you don't mind nice second hand lights.
If you are in the US, they Rayovac Indestructible could be a nice budget light at Home Depot or similar stores.
:welcome:
Funny, I was looking at a small single AA forward clicky as a backup EDC, and SHTF light.
What I came up with is:
Jetbeam PA10, or BA10. The PA10 has more modes that needs to be programmed and has a lower low, but costs more as well.
FourSevens Quark Tactical QTA. Programming needed, I thought about the Pro with tactical switch, but I think modes will change on the fly with quick momentary use (not sure).
Nitecore MT1A. It has non hidden flashy modes, and on one side of the mode groups change modes with quick momentary use. A cheaper, slightly different PA10?
Klarus P1A. I feel like it's the same thing as the BA10.
Fenix E11. Small, but the low is 32 lumens.
ShiningBeam C Mini or Spark. Seems like the same light, will have to get the AA tube for either one, but seems versatile in terms of what it will run on. Not many reviews though.
ShiningBeam I Mini or Value I Mini - Different UI that I think it kind of weird and troublesome if you need to change modes a lot. Value I Mini with AA body tube ends up being cheaper than the I Mini set (you lose warranty time though); go figure.
Most other forward clickys that do momentary will shift through modes which I don't think is all that useful. Seems like something the flashlights just happen to be able to do because it's a forward clicky, but the manufactures just call it a "feature". So everything here is pretty much a click on/off and twist for another mode.
The other ones that have two buttons, one for on/off, one for modes would be the
Klarus XT1A, and Fenix LD12, but they are more expensive than the other non-programmable ones.
Quark AA2 Reg/Tac/Turbo XPG2 or XML emitters.
Then get a AA tube should you decide to go lithium ion (14500)
10-year warranty, best customer service (hands down)
Might be all you ever need in an EDC. Been using mine for close to three years now. :)
Thanks again for the help.
After comparing lights I decided that the JetBeam BA10 looks like the best fit for my needs and made my order. There where only two things I wasn't fully happy with. First it doesn't look like it can handle 14500s. I doubt I'd be using them anyway so this doesn't matter. Second is that I've seen some indications searching this forum and online that JetBeam's quality control isn't fantastic and that some people find the tail switch squishy and, in a few cases, unreliable. The QC issues seem to be limited so – for the price point – I can live with both of these.
As for the other items on my short list :
The Olight i2 uses a twisty head for on/off instead of a tail switch which puts it out of consideration. I had it on my list because, from their website, I couldn't tell how it worked.
The Fenix LD12, FourSevens QPA and QTA, and the EagleTac P20A2 all look nice but they have more modes than I want to deal with right now and are more expensive than simpler models that match my needs equally well. When I have some more money I may consider buying one of these for fun.
NiteCore MTA1 looks really nice and the ability to easily switch between Turbo and another setting without cycling does a lot to mitigate the complexity of so many modes. If I had been able to find any reviews last night I would have had a tough time choosing between this and the BA10.
Fenex E11 is brighter than I want at the low setting, doesn't appear to have a clip, and I don't like the styling.
ShiningBeam I-Mini was a close contender but it won't tail stand and the infinite variable brightness – while cool – might be inconvenient for day to day use.
The ShiningBeam Spark seems nice but I don't want to cycle through all of those modes and the length of the 2xAA body is on the upper end of what I want to carry.
The Klarus P1A looks very similar to the BA10 but appears slightly more expensive.
