jason331
Hi everyone,
I'm looking for a decent everyday-carry light. I work as a residential A/C installer, plumber, and electrician so I frequently have to crawl through dark places in attics, under houses, and other generally unpleasant areas. I also do some hiking at night and other general rural activities that often find me out in fields and in the woods when it's dark. I've looked at the Streamlight 74001 Strion, Fenix PD32 Compact 315 Lumen LED Flashlight, and the Olight M20S Warrior Premium R5 Black Tactical Flashlight with Side Switch 320 lumens but each one seems to have various pros and cons that I feel like I would be sacrificing too much to be happy with the purchase. My budget is very flexible but ideally I would like to stay under $300.
- How would you prefer to purchase the light?
I will be mail-ordering or buying online, so this doesn't matter. - Budget: An easy question, but you may change your mind after answering the rest!
I’m flexible, tell me what you got - Format:
I want a flashlight. - Flashlight-specific format/size:
Every day carry medium (4-7 inches). - Emitter/Light source:
LED (known for efficiency, longevity, and compactness) - Manufacturer:
I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box. - What battery type do you want to use?
I intend to use rechargeable lithium (li-ion) chemistry. <-- important
I want a light with an integrated rechargeable battery. <-- preferred - How much genuine out the front (OTF) light do you want/need?
I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens). - Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
50-150 yards/meters (I live in a very rural area/farm with wide open spaces) - Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
90-120 minutes (Runtime is moderately important, but still not critical) - Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
Very Important (Camping, Backpacking, Car Glove-box). - Switch Type and location (choose all that apply):
I want a tail mounted switch (found on the majority of today’s high end lights). - User Interface (UI) and mode selection. Select all that apply.
I want multiple light levels. (Some lights have 5-16 light levels.) - Material/Finish/Coating
Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
Stainless steel (durable, but much heavier than aluminum)
Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
