turbodog
I need a light for the following problem. Will likely have to build something... but you never know.
Have a tornado shelter. Recently needed to get into it in the middle of the night in a big hurry. Did not have time to grab a light.
When got IN the shelter, needed a light immediately in order to close & lock the door. Depending on who may be in there (ie, not myself) they will not know where a light stashed in there is, how to turn it on, etc. Will quite likely not have time to find/figure this stuff out either.
I want to put a light in there with a string across the doorway. When you want through, the light comes on as you pull/run into/trip across/etc the string. It would be hooked to a switch that turns on and stays on.
Could NOT find anything like this using google.
If I have to I would build using a 4d battery box, emitter, heatsink, spring loaded microswitch with a paperclip holding it closed, and string tied to paperclip.
