well, IF there was enough room, and money available for it, i would use this curcuit.
http://www.taskled.com/leds/nflexuib2_v1.00.pdf
its very well done, or even overdone, the interface is very simple, it can go on/off quick and jump to a low Quick, but it wont do the momentary thing you want :-(.
the one thing i can think of that does the momentary the way you want it a Nite-ize(sp) switch, but the nite eyes switch just has a bit of resistance, not a regulation, and is designed for the back of a tactical type of tube light.
that nflex, will change in current (deep in the UI menu), so if you got tired of it actually Working at 500ma, you could crank it up to 750ma and have fun blowing the bulb out instead.
it has different ways of setting a cutoff.
it sounds horribly complex, but it isnt at all, 4 wires to connect like anything, locations well marked and easy to get a wire on to.
the interface also sounds complex , it is complex to set the (one time) current rating, but after that even a 4 year old could operate it.
then of course 2 cheap chargers or a multitap charger , wiring up the li-polys to the charger jack, and wiring 2 chargers or a multitap charger to the plugs.
adding protection to each li-poly is about $2 and very small, or buying preprotected cellphone or pda/ipod packs would be prewired ready to go.
i would say "piece of cake" but nothing ever is, its just very possible.
the problem with that nflex curcuit, is it wants a momentary switch , not your usual click on/off type of thing. and there is a tiny drain that will drain the batteries in about 1 whole month.
the "parasitic" drain of it waiting for your click, can be solved by having a disconnect switch.
For example, in a mag mod, you use the MAIN switch to disconnect the whole thing, on and off it comes back to the posisition it was last on.
then you ADD in a tiny momentary that will do the adjusting.
soo in a light like what you showed (very little of) use your main switch as the disconnect, just like before, and find a location for a tiny momentary switch, a membrain switch like from an old stereo, or the smallest momentray at radio shack will surface mount easily. when you use the normal switch it will go on and off as before, when you push the Other switch it will change in levels, and you can acess the current control.
all of that might be WAY beyond your needs, as changing levels was not mentioned at all. but it sort of "finishes" it in one move, changes can be made through the software UI interface, to adapt to your desires at the time.
another route would be to just toss in one of them cheap small china curcuits that is used in the leds, get a 500ma one that works with the (up to) 9V.
the key reason to use an nflex would be to change current drives at will, a valuable assett.
Adding : the Bflex Also does about the same thing as the nflex, and is in a smaller package, both can have a cute little led now for a battery light
