Packhorse
Im looking for a light to modify into a light head for a dive cannister light.
A C or D celled Mag is the most common to use but I am wondering if there is something else out there that could work as well or better.
Requirements.
Needs to have a large head. preferably something MR16 (50mm) or MR11 (35mm??) drop in compatible.
O ring sealed
Ability to change the lens to a thicker one (4mm+).
The switch will have to be removed. If its in the tail cap then it will be replaced by a cable gland. If its on the body then that section will have to be cut off and rethreaded/ glued into the head.
Is there a light where you can remove the body and screw the tail cap directly on to the head?
Requirements.
O ring sealed
