Lost E1B - Need new EDC :(
LuLuTheMonk
Lost my E1B on a flight and so now I am in the market for a new EDC.
____I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____I'm flexible, tell me what you got.
3) Format:
____I want a flashlight.
4) Flashlight-specific format/size:
____Keychain size.
____Every day carry small (2-4 inches).
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
7) What battery type do you want to use?
RCR123
____I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
11) Durability/Usage: Generally the old phrase 「you get what you pay for」 is very accurate for flashlights.
12) Switch Type and location (choose all that apply):
Something similar to the E1B
____I want a tail mounted switch (found on the majority of today's high end lights).
14)Material/Finish/Coating
____I don't care.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
Would like a pocket clip that doesn't leave a lot of the flashlight exposed.
____Pocket/belt clip
E1B is about the maximum size I am comfortable with in my pocket, unless maybe it was significantly slimmer with huge performance gains. I still have my E2DL, which is why I would prefer to use RCR123's, but I could be convinced to get another battery type if necessary.
Thanks.
l looked through selfbuilt's reviews and it seems that the jetbeams have deeper reflectors than a lot of the others in that size range. the bc10 seems like its exactly what your looking for.
Anybody else with any other recommendations? From going through the self built thread, it looks like I might have to get new batteries anyways?
