LSL Cell & Twisty Questions
Status
Not open for further replies.
jayflash
Two Rivers, Wisconsin
Will any Arc twisty work with all LSL's? Is this the same as J.S. Burly's twisties? Will any arc twisty work on an LSL that came with a Kroll? Best place to get a twisty - J.S. Burly?
My LSL consumes 460mA with 123 cells, about 400mA with two alkalines, and 300mA with rechargeable cells. Any ideas why the difference? The measured light output is the same for all types of cells so are there efficiency loses with the 123's?
jayflash,
All the tail packs should work just fine on your LSL. TSP and twisty. There are several versions of the twisty pack, and all of them were sometimes in need of a spacer(small washer/tin foil)to make proper battery contact. Not a big problem. I have a factory Arc HA twist pack that I could sell you that is mint and in working condition. JS Burley is also a good source, but you will need to remove some HA on the threads and inside on the battery contact. I think they are $15.00 plus shipping. As for the current draw question, it should be different for a given cell but others here could give you a much better information than I can. PM me if interested in the twist pack.
Brandon
Status
