Superorb
It will not tailstand at all with the DX tailcap the way I have it.Does it still tailstand with the DX GITD taicap? And if so do you remember the SKU#?
Does anyone know if the high or medium level will drop in output or drop to the low level when the battery starts to get drained or does the light suddenly leave you in the dark? I guess I'm asking if there is any type of moon mode to give warning that the battery is being depleted.
Thanks.
I'm testing it now with an almost-depleted Duraloop on High. It seems to have stayed in high for a few seconds, then dropped to medium and then low pretty quickly. The battery was dead in other lights, so I'll retest again.
EDIT: I'm starting on medium now. I'll report back later.
This is probably the best method because it doesn't require another tailcap unless you want one with a cap that extends out.I put a little shim, about 1-2 mm thick (I used some spare sticky plastic stuff) under the button. It makes the tailcap stick out a bit more when off and produces a slight wobble when on.
This allows tailstanding and makes for much easier activation. Any shim material will do, and you can experriment to get best feel with tailstanding.
