Just got the lumapower M3 from batteryjunction and I have to say it's a nice light but let down by a few niggling build issues.
Firstly the hi-lo switch (turn of the head) barely works because the battery tube has to be tightened so hard to push down the little switch in the head for hi that it's then impossible to then loosen it for the lo setting without some two-handed wrestling.
Similarly, when the AA extension tube is screwed on it doesn't tighten enough, leaving a small gap between the sections that kinda detracts from the "single tube" look. Now it just looks like two badly-fitting tubes screwed together.
And finally the tactical switch is nice in theory but requires far too much pressure to activate -- a particular problem with such a smooth, slipperly flashlight. You really have to grip this thing and have a strong thumb to operate it otherwise it either flies out of your hand or just doesn't go on.
The first two issues can probably be fixed by taking a file to the ends of the tubes to shorten the threaded sections. I'm not sure if the tactical switch issue is normal or not. Anyone else have similar issues or suggestions on how to fix them?
