LumaPower MRV - 100 & 200 m Beamshots & Runtimes! MRV Deconstructed. Now FluPic'd!
StefanFS
Silicon Road 1, Sweden
LumaPower MRV - Beamshots & Runtimes! UPDATED!
At last "IT" arrived in the mail.
A group photo. From the left: LumaPower D-Mini, Dereelight CL1H with 6-mode dropin, Eastward YJ U2 style and last the MRV.
Same order as above. The business ends.
To switch levels turn the plated light engine in relation to the body. Clockwise to go to high from low, and counterclockwise to go from high to low. Don't tighten it too much clockwise, that could loosen the switch mechanism. A soft click indicates the switch between levels.
The extreme reflector with GITD o-ring between bezel and lens.
Tailcap with aggressive cutouts. Very nice to use and easy to click.
Two shots to show the different textures, HA vs plating.
Tailcap with reverse onestage clickie installed. Note the treated threads on the battery tube.
Light engine and head taken off.
Head with light engine taken off as a unit from the battery tube.Also shown is GID switch cover, spare o-rings and the momentary push switch (screw on for constant light).
LumaPower D-Mini on the left, MRV on the right. @ 2 meters. Both on one 3.7 volt LiIon. F/2.8, 1/200 s, ISO 100. Waaaay underexposed and taken in daylight. Better shots will come later, from various sources no doubt.
The GITD o-ring in the bezel.
This is how the underside of the light engine looks like when you screw out the plastic retainer for the mode switch. Under the plastic cover there is a switch with a resistor on the board. On the switch there is a small spring with a brass contact resting on it, the same brass contact you see when you disassemble the light engine from the battery tube. That makes contact with the brass contact screwed down into the battery tube. When you tighten the tube clockwise against the light engine assembly it puts pressure on the switch and when it clicks it bypasses the resistor for high mode.
This light is like no other. I think you need to hold it to understand that. It will momentary blind you if you look into the lens and CLOSE YOUR EYES before you turn it on. The plated light engine looks very nice in real life, it's not mirror shiny. More like machined and semi polished stainless steel. HA is a sort of gray green that is very handsome on this light.
Throw Lux @ one meter:
· 18650 x 1 on high: 10100 Lux
· 18650 x 1 on low: 5700 Lux
· RCR123 x 2 on high: 11500 Lux
· RCR123 x 2 on low: 5900 Lux
(In the table presented by LumaPower Lux @ one meter are:
18650 x 1 on high: 16900 Lux
RCR123 x 2 on high: 20100 Lux
I not totally clear on whether LumPower is stating throw Lux or total output. 16900-20100 Lux in throw seems outrageous @ 1 A even considering the larger reflector. My guess is that these figures reflect total output, especially since the MRV have a large and bright spill area which is much brighter than the D-Mini.
As a comparison, my D-Mini with an Cree Q2 dropin led engine driven at ~1.3 A produces 12600 Lux in throw.)
LumaPower have announced that the throw Lux figures published earlier are from Engineering Samples with a much tighter hotspot and less spill light than current versions. The current version of the reflector is in the light reviewed here. The new reflector have more useful spill light and throw numbers are in the range of 10000 Lux and up depending on cell/s used.
My conclusion
This is a magnificent flashlight. Very nice. Very high quality in my opinion. Construction is very well done and the light is rugged, it feels massive in the hand. It's possible to disassemble it completely, save for the light engine internals, and all parts fit together snug and tight. No loose threads or other inconsistencies in construction. It's very bright with excellent throw capability, and at the same time it produces a bright and large spill area.
I'm very picky with my equipment, but I can really recommend this light to anyone who wants a good flashlight in this size and class.
The only two weak points would be the mode switching assembly under the light engine, part plastic and a delicate switch, and the GITD o-ring between the bezel and the lens. The o-ring should be kept in place by a ridge in the bezel to stay in place securely when the bezel is tightened down. It takes a fair bit of abuse to compromise the GITD o-ring, you have to overtighten the bezel quite a lot to get the o-ring to pop out. The mode switching assembly also needs to be abused to stop function as intended, if you overtighten the battery tube hard, clockwise, against the light engine one of the switch retaining parts can come loose. What happens is that the low mode disappears until you take the battery tube off and tighten the relevant part down again. The light still functions, only the mode switching is affected. But, you need to abuse the light quite a bit for this to happen.
Now some real life beamshots.
All nightshots are taken with an 8 second exposure time. Also note that the sky doesn't go totally dark this time of year in Sweden. The 8 second exposure time is very close to what I saw with my bare eyes when I did this. I took my likely throw candidates, the spotlight was just for fun, but I found that it had its place in this.
From the left: D-Mini on RCR123 LiIon, MRV on 18650 LiIon, 5 D Mag with Mag halogen bulb on alkaline, "2 Million CP" Spotlight 6 Volt.
Throw Lux: D-Mini 7800 Lux. MRV 10150 Lux. 5 D mag 14000 Lux. Spotlight 33000 Lux.
The first setting.
The end of the road is 100 meters away. Composite picture first, then the individual shots.
The second setting.
The treeline is 200 meters away. Composite picture first, then the individual shots.
MRV bonus image, probably a bit over 100 meters. Very nice.
About the distances involved in this, they are known. Both by official map and by measurement. Here is a nice sat/air shot of the area.
Two shots just to show how "perfect" the MRV hotspot is. Why use white walls for hunting when there are rune stones standing around. Second shot shows the corona around the hotspot. There are no rings that I can see in the MRV beam.
MRV. 1 m. F/5,6 1/50 s.
MRV 1 m. F/2,8 1/30 s.
Inscription on the stone, literally: Inga had this stone inscribed for Aslak her Stepson. Age on the stone is +1000 years.
Runtimes on RCR123, 18650 LiIon & CR123A
Runtime with RCR123 on the high setting. 25 minutes of 100%, then it shuts off. If you let the cell rest for a few minutes it will come on again for a minute or so. Expect much better runtime with primaries since they hold much more mAh than RCR.
RCR123 on low. 2 hours and 20 minutes.
Runtime with AW 18650 LiIon 2200 mAh. 3 hours and 15 minutes to 50%. Usable light up to 4 hours and thirty minutes. Expect low to have at least 12-15 hours runtime, I'll do that one when and if I have time for it.
This is the result from Energizer CR123A primary cells. MRV on high. about 53 minutes to 50%.
I went one step further with this review. I disassembled the light engine to get the driver pcb out from my MRV. Before I disassemled it I desoldered the positive lead from the led in order to get milliAmpere readings to the led. They are as follow, with the stock driver circuit and fresh cells:
On AW 18650 LiIon:
- Low 410 mA
- High 830 mA
On two RCR123 LiIon:
- Low 410 mA
- High 1190 mA
On two CR123 primary cells:
- Low 410 mA
- High 1190 mA
The space in the driver compartment is: 7.2 mm in height. The driver pcb is 17 mm in diameter. Including the brass contact ring the pcb is 18.85 mm in diameter to fit the depression in the light engine.
A magnified picture of the stock driver.
The backside of the stock driver. This miniature click switch is what changes the mode when you turn the body, it's what makes the soft click when you turn the battery tube to go low or high.
This is a picture of the led mounted in the light engine heatsink. It's glued to the heatsink with some spongy thermal epoxy, it's a very thin layer of it under the mini star that holds the Cree emitter.
See post #120 for modification with new AMC7135 driver.
See post #133 for modification with FluPic.
See post #169 for CREE X RE Q5 WG bin installation.
Stefan
Update 2007-08-23
I have received another MRV, this is the new version with dark brown hard anodized finish and dark chrome on the light engine heatsink.
Fit, finish and build quality are very good, better than the previous version. Flawless anodizing, better threads, stiffer spring in the midbody switch mechanism. The glow in the dark lens o-ring is held in place more securely than on the first version. Output is up a bit from the first version, likely due to the CREE Q2 used in this version. Driver seems to be the same model that is used in the first version MRV.
Finish is very good. Here beside the first version.
Anodized and deeper threads on the new version.
Output is slightly higher on 18650. Definitely higher on CR123 and RCR123.
Old version. Throw Lux @ one meter:
· 18650 x 1 on high: 10 100 Lux
· RCR123 x 2 on high: 11 500 Lux
New version. Throw Lux @ one meter:
· 18650 x 1 on high: 11 300 Lux
· 18650 x 1 on low: 7200 Lux
· RCR123 x 2 on high: 14 350 Lux
· RCR123 x 2 on low: 7100 Lux
· CR123A x 2 on high: 14 400
· CR123A x 2 on low: 7100 Lux
Further beamshots with the MRV will be in a new thread:
http://www.candlepowerforums.com/vb/...57#post2105757
Re: LumaPower MRV - Something Else Entirely!
Nice shots. I look forward to your further impressions. I just ordered one of these this morning. Kind of an impulse thing.
P.S. Am I the only one that thinks "LPower Uma" when I see their logo?
Thanks for your review, the wait is beginning to actually hurt..
Double O-rings too, do the parts go on and off easily? Also is a two stage switch
availible? :)
availible? :)
The light is two stage. Built in.
I like what they've done with the beam, compared to the D-mini nebula.
Interesting lux figures...I do believe Lumapower was measuring lux at one meter in their figures as well :sssh: It will be interesting to see more independent results!
I usually get lower lux reading than most others do as well, but overall output readings are pretty accurate on my part. I wonder if it's in the way the meter is set-up for lux. I put my meter at one end of a cloth-covered ironing board, and the flashlight one meter away on the other side. Whats your set-up?
StefanFS said:
[*]18650 x 1 on high: 10100 Lux
[*]18650 x 1 on low: 5700 Lux
[*]RCR123 x 2 on high: 11500 Lux
[*]RCR123 x 2 on low: 5900 Lux
Great preliminary review StefanFS, I'm anxiously awaiting mine from Matt.
To give us D-mini holders some perspective, do you have lux readings for your D-mini to compare these results to?
Could be a communication error in the sales thread. Or my MRV is a bit off.
I do Lux @ one metre in our dark closet, the lux meter is on piece of cloth and I'm using a one metre stick to get the height right. There's nothing wrong with my meter, it checks out on my other lights. With my bare eyes the MRV does have a bit more than double the throw when compared to my D-Mini. Maybe my Lux meter freaks out, but it's rated to go up to 50 000 Lux.
Stefan
My D-Mini on high with the stock driver, throw Lux: 7400-7800 Lux depending on what condition the LiIon is in, it seems to fluctuate, even with the same cell between charges. If you really work on finding the perfect focus point the D-Mini can go up to 8000 Lux.
StefanFS said:
My D-Mini on high with the stock driver, throw Lux: 7400-7800 Lux depending on what condition the LiIon is in ...
Hmm, seems pretty consistent with what Lumapower themselves report for the D-mini, so it seems like your lux meters are similarly standardized. I guess we'll have to wait for a few more specimens to get out there ...
Thx for prompt reply StefanFS ... enjoy the light (and the thread count hits). :grin2:
Great review StefanFS.
Strange thing about the lux readings?
Since i got my MRV today as well,
im just curious where in Svealand you live?
If you would like to measure mine.
But im not so keen on sending it by post
(i just got it)
I live in Haninge.
The most useful and revealing beamshots will be those comparing the MRV with other "throwers", taken outdoors using buildings, trees and other objects at known or approximated distances.
Brightnorm
OK.. Glow ring in bezel looks great.. Did it come that way or that a ring you added?
Brightnorm
That's definitely in my immediate plans for this magnificent flashlight.
Thujone, the GITD o-ring was installed when it arrived. Don't twist down the bezel too tight, it will bungle up the o-ring.
About the output. 20000 Lux as LumaPower states with 2 x RCR123 would be somewhere in the neigborhood of 240 Lumen, which is the stated maximum output from an CREE X-RE, according to CREE themselves in their specification. OK, thats total output at the led, but I think it may be that the figures 16900-20100 Lux are derived from the max output in the CREE specifications. I feel that it's not realistic to expect 20000 Lux in throw from an Cree X-RE led driven at 1 Ampere.
My MRV throws a bit over 10000 Lux, and total output should be a little bit more than that. My guess is that the MRV's total output out the lens is over 150-160 Lumen (factor in losses in the reflector and the lens and you might be a lot closer to 200 Lumen). Which is incredibly bright. My MRV is visibly brighter than my Eastward YJ U2 style, and that one produces over 130 Lumen out the lens.
Stefan
waterproof? and i guess i can assume this is a SPOT light and not much flood? also, your cree dropin throws further than this according to lux numbers?
It has about the same flood area as the Eastward YJ U2 and almost as large as the Ultrafire C2. It has a BIG reflector. Real big flood with this one.
It has a powerful spot with a generous spill as I understand it - not quite the same as flood. I believe spill is usually defined as the secondary cone of light that comes a flashlight, which is a separate entity from the focused beam itself...
Please correct if I'm mistaken! :)
