LumaPower's D-Mini VX ULTRA
JoeN_Ffx_VA
Received mine Friday from batteryjunction. Can only use with a CR123 primary until my 18650 comes from 4Sevens. Output is OK nothing spectacular but previous threads say have to use the 18650 to get full benefit.
But have a basic question. The writing on the side of the body says LumaPower D-Mini VX and under it a tiny tiny s/n : D-mini-VX and #s can't read.
The instructions in the box says ultra but is it really? I'd have expected it to say ultra or is there some other way to tell? thanks
No, they don't say, "Ultra" on the torch. I picked mine up last week at their store in CT and this is a truely amazing light when you use either a 16340 rechargeable with the short tube, or an 18650 in the longer tube. Since my goal with this light was to use in in the compact mode, I have been running the 16340 Ultrafire 880mAh rechargeable. This torch is actually brighter than a recently purchased Olight M21 and almost as bright as my Olight M30 Triton. Beam is a fairly wide spot with lots of spill, so very useful in lots of situations. If you need long runtimes, use the longer tube with the 18650. The big difference is that you pick up the extra .6 or .7 Volts with the rechargeables. Good luck and enjoy! :twothumbs
As fiveform mentioned, just wait until you get your 18650 or if you order the 16340 (which I did with mine), you'll be pretty pleased by the overall output.
Re: the "Ultra" label, I had posed the exact same question to the mfg and I'm sharing Ricky's responses since I'm sure others will be interested as well:
Q1: How can I determine if my VX Ultra is truly an Ultra and not just
regular VX? The case does not distinguish this as an Ultra but just D-Mini
VX.
A1: The main difference between the D-mini VX and D-mini VX Ultra is the LED itself. The die size of a SST-50 is much bigger than the XR-E.
Each side of LED with 10 bonding wire within. The XR-E only with 4 bonding wire.
Q2: Thx for the reply, I’ve taken it apart and confirmed it’s SST-50 LED. However, I actually meant visually on the product. My flashlight only says VX on it and no Ultra. Will you ever release these with the Ultra on it?
A2: At this moment, the SST-50 is very limited in supply. So, we do not have a plan to make a special lasermark on top.
Great flashlight, enjoy it!
Cheers,
Tim
Can someone please explain how to use the 18650 tube? I changed the led to the larger tube but it won't work. Something else needs to be done and I haven't figured it out yet. Instructions don't mention anything.
Thanks.
There is a spring in the spare parts bag. Put the spring between the light engine and the battery tube.
Merry Christmas
Per NSB's reply, take the spring and put it into the hole in the pill side. It should look like this (do not try to make the spring flush as it needs to make contact with the pill):
Tim
Yeah, the spring thing got me too- put the extended tube on, dropped a battery in, and nothing. Took a look and realized the battery button wasn't anywhere near making a connection with the pill. I saw the spring in the spare parts bag and thought it looked just right for making the connection. They might have mentioned it in the instructions!
VX.
Cheers,
Tim
Hi Tim,
thanks for the info. I counted 8 bonding wires on 2 sides of the die, not 10 or 4. Any idea what that means?
The 18650 battery arrived. Light output much much better than a primary 123. I'm only measuring 1.2 Amps on high tho my test circuit may not have been ideal. I've seen 2+ amps reported for this device.
Hey fiveform, this is the type of info I've been looking for and luckily the search function allowed me to find your post.
I've been looking for a high-powered light for a while and had my mind set on the M30 Triton for a while until I found out about the LumaPower D-Mini Ultra.
Do you have any comparison pics showing the lights themselves, as well as beamshots? How much brighter do you find the M30 over the D-Mini?
I've got the D-Mini on backorder but it isn't too late for me to cancel and order an M30. I was kind off dissuaded from the M30 after reading about all the PWM flicker it seems to have.
Thanks bud.
...I'm only measuring 1.2 Amps on high tho my test circuit may not have been ideal. I've seen 2+ amps reported for this device.
Good question, I actually only count 7 on each side:
As for the Amps, it may be related to the battery you are using but I'm not an electronics whiz so maybe someone who knows better can chime in.
Thanks bud.
Don't have a M30 to compare to but here are some comparison pics vs. DBS V2 R2 and RRT-0 (Zebralight thrown in for reference/fun):
http://www.candlepowerforums.com/vb/showpost.php?p=3220536&postcount=41
Cheers,
Tim
