Lumens Factory EO-4
Tried a search but came up empty.:sigh:
Has anyone tried this bulb? Thinking of trying it in my SF M2 with an AW 17670.
Thanks,
Tim
That's a high-drain lamp that might not perform as you may expect at only 3.7 volts. It's better to use something like the HO-9 on 2x16340 IMR cells. Or the IMR-9 or P91 for maximum brightness.
THANKS for that tip!!:party:
Had not tried that search option before, got all kinds of info to read.
Yep, I thought that. The CPF search doesn't get too short words . :thumbsup:
The Outdoors Fanatic's tip also is good for better output performance.
PS.: Put a P91 into your pretty M2 and forget runtime :cool:.
Cheers,
Dioni
Well, with some of the higher output options that were mentioned, I kinda wussed out!!
I went with the HO-4. It is fairly comparable to the stock P60, maybe slightly dimmer, but it should run for at least an hour on one 17670.
If I need more light, I've always got my M6 with an 1185 in it:D.
Tim
