StainlessSteel
Is it OK to put the High Output and Extreme Output bulbs into Surefire Nitrolon lights, (G2, G3)?
I was thinking about running the LF HO-9, 320 lumens, in a Surefire G3, powered by three 123a batteries. Should I be worried about overheating or melting?
I ask for two reasons
#1 The Nitrolon G series are NOT listed in the "Compatible with:" section on the Lumens Factory web page.
#2 Most of the super bright LED drop in makers recommend metal lights for heat sinking. Is this the case here?
Thank You.
Thank You.
