Re: Luxeon heat issue.
Hi KS
It's perfectly normal for luxeon flashlights to get warm within a few minutes during use. How hot they get depends on how hard the luxeons are being driven, how long they're run for and how warm or cool the environment they're in is.
Although there are a few plastic bodied lux lights around, most are metal and radiate heat away from the lux and into the air. Provided that the air is not too hot, the light body should eventually reach an equilibrium where it is radiating as much heat as it receives, and so should not get any hotter. Apparently lux emitters should not be heated to over 100 deg C (212 deg F) or so. I'd be very surprised if your T1 or any light from a known manufacturer would get that hot in any normal cirumstances - unless you like wrapping your light in bubble wrap or putting it in the oven /ubbthreads/images/graemlins/smile.gif.
I've never had an occasion to run any light of mine for more than an hour or so, and none of them got too hot (and where I live it's 28-32degC (82-89degF every day).
