luxeon regulator circuit
turbodog
central time
Are there any circuits that will regulate a luxeon in constant current mode. Here's the catch, I'm looking for something that will go in series with the batteries and led.
Variable input/etc gets extra points.
My dream part would be constant current of about .6 amps, input variable from 2 cells to about 6 cells.
While I think this can be done, I think the minimum would be 3 cells and efficiency will go in the /ubbthreads/images/graemlins/smoker5.gif with more than 4 cells.
It might be possible to make a buck regulator to wire in series, but again a 3 cell minimum. I don't see any way to do a boost circuit without having a third connection! Even with 3 cells you'd have to have a low Vf Luxeon and tolerate not fully dischaging the cells (as would be typical of incandescant flashlights).
As GWB just said, for what you want the battery has to be higher than Vf. There are a few two terminal circuits that will do this, but you'll need nearly a full volt more than Vf for any I know of.
Doug Owen
maybe a Boost/Down circuit like the Wizard?it can be wired in series, just as long as the barrel of the lite isnt negative terminal!
[ QUOTE ]
[/ QUOTE ]
Does not meet the request! This is 4 terminals! Request was for something to be wired in series with a Luxeon and the battery only. No full connection to the battery.
The circuit I had in mind works to about 0.13 V above Vf but not at 600 mA. The output transistor is only a 2N3906 (rated 200 mA max.) It might be possible to use a transistor that could handle a higher current but the minimum voltage will likely also increase. The circuit comes from Bob Pease the designer of the LM317 and uses the LM334, the 2N3906 and a 1.6 ohm resistor (for 40 mA).
edit:
Oops sorry, just realized that wired as a two terminal this circuit would require 1.4 V above Vf to regulate! Still better than a LM317 at 3.4 V above.
