The Lumileds data sheet for the 5W stars cautions in Note 3 on Page 2 that: "Electrical insulation between neighboring stars is required -- aluminum board is not electrically neutral."
Artic Silver says: "Caution! Even though Artic Silver Thermal Adhesive is specifically engineered for high electrical resistance, you should keep it away from processor, memory, and motherboard traces, pins and leads. The cured adhesive is slightly capacitive and can cause problems if it bridges two close-proximity electrical paths."
It sounds like a small degree of connectivity in the LS base is further diluted by the largely resistive Artic Silver.
Has anyone mounted multiple stars to the same aluminum heat sink with Artic Silver? I would really like to mount four LS Stars on a Zalman SM80A-HP VG heat pipe cooler. (http://www.zalmanusa.com) This quadruple finned surface unit would be shorter and no deeper than the head unit of the small lantern battery light that it will replace. The battery chamber can hold either 8D cells or 1 lantern battery providing room for a 9.6 V 4.0 A C cell rechargeable battery pack and four separate Power Pucks to deliver a regulated 700 mA to each separate LS.
