ElektroLumens
Here are some results of a new little regulator I just put together. It is just one inch in diameter, and uses the MAX756 8 pin DIP IC. I started with a single not real fresh 'C'battery. It lasted 5 1/2 hours before I shut it down.
12/19/2001
TIME Vin Vout
9:25 1.306 3.085 Start (Battery not completely fresh)
1.53 .915 2.937
2:16 2.928
2:38 2.916
2:50 .803 2.898
2:57 .775 2.878
3.08 .641 2.814 Shutdown, but still shining.
5 hours, 43 minutes on one 'C' battery.
I hope to do this same test with 2 'AA's and with 2 'C' batteries, and also do amperage testings as well.
The output of this one inch disc is a little less than with the 1" X 2" board I have, probably because of the small surface mount capacitors being used.
12/19/2001
TIME Vin Vout
1.53 .915 2.937
2:16 2.928
2:38 2.916
2:50 .803 2.898
2:57 .775 2.878
