Deft edc was 40k candlepower instead of lux
Would anyone do a 1m lux reading @@?
40K cp = 40K lux @1meter. They are one and the same.Deft edc was 40k candlepower instead of lux
I have a Deft EDC and it is amazing how well it throws. It is so focused that it needs to be used at longer distances only because the hotspot is so small close up.
Have you read the original thread here? http://www.candlepowerforums.com/vb/showthread.php?318156-The-DEFT-EDC-is-out!
No there are no plans for that. I am a big proponent of rechargables. Better for the environment and your pocketbook.:DAmazing. Any plans for a version that will accept two cr123's also?
You pretty much jump from 10k to 40k lux for anything less than 1 1/4" in diameter. Nothing in between.
Grumpy, I'm interested to hear your thoughts on this. You said it needs to be used at longer distances because it's so focused. What distances are you guessing?
In full throw mode I would say roughly 150'-200' is the minimum. With the diffuser in the full diffusion position I'd say the minimum comes down to about 50'.
Not sure off the top of my head. I will get that for you tonight.What is the size of the beam spot at 50 yards? 100?
