ergotelis
you are right hill, when i will have the regina reflectors i will post side by side beamshots with mcr20,regina,derelight xpg and anything else interesting if i have.
I have a Quad XPG using Downloads reflectors and a Triple XPG using LXP optics
Would that be a fair comparison ???
I have some Regina reflectors on the way as well, hopefully
I'll get them sometime this week.
Then we can get some proper comparsion beamshots done :D
I am curious if it is possible to do 4 xpg r5 in a square sitting directly next to each other? You could then use a single large reflector for the light.
That type of setup would produce mostly flood since the emitters would be relatively far apart. One would need a huge reflector to produce any amount of reasonable throw. Better to use an MC-E or P7 if you want a quad emitter.
Far apart? They would all be as close as they possibly could be to one another. It doesn't seem like it would be any different than a MC-E or P7 just with 4 leds all in the same area taking its place. The R5 emitters have longer throw normally anyways, so it seems like if you could place the reflector correctly it would be an awesome setup. You would have tons or brightness, flood, and throw.
How are these reflectors compares to your other <Mag with triple LXP optics?
I sold my Triple LXP a while ago, I still remember the snow white beam when paired up with the Kai domain XPG R5, never seen anything quite like it,
when I put the same XPG R5 in OP reflector, it's not as snow white.
Maybe Hill can comment on whether using the LXP or the Download reflector
makes any difference to the tint of the beam that our eyes see
What I can say, is that the overall size of the beam from the LXP is half
the size of either reflectors.
Thanks. I still have one LXP & thing about putting into an EDC,
so the LXP still has the tightest spot then, given the same lumen,
thus translate into more throw than the reflectors?
thanks
