Wattnot
Hi All. I've ordered and received all parts needed for converting my 3D Mag to a Mag85 - EXCEPT for Kiu's socket. I don't know if it's the New Year holiday or the bad weather but it's not here yet.
But I started taking apart the light and installing what I could. That's when I discovered the socket might not work since the pictures in Kiu's thread don't match what I've got here. Take a look:
The nickle is included for a size reference. This Mag is probably over 20 years old. There are threads inside the Mag tube that match up with that "disk" thing, which sits on the top of the socket assembly. Does it appear that I'm going to have a problem with Kiu's socket? Should I get a potted lamp instead and go with the stock socket? The only problem then might be that my non-cammed reflector has a smaller hole. I'm sure the 1185 will fit through the hole but the current, stock PR lamp will not.
Ideas?
Thanks!
Ideas?
Thanks!
