hoongern
Hi guys,
I recently acquired a Mag2D, and decided to build a Mag85 (later to be upgraded to a Mag09 with the FM1909 bulb).
I built it using a Kiu socket, KD V3 SMO aluminum (15mm) reflector, and borofloat lens (still on the way). Currently being powered by 3xIMR18500 in a PVC pipe, later to be changed to 3xIMR26500.
For reference, I went to a DIY shop and bought a pack of "soda" crystals (for drain cleaning) for just $1.50, and that and a bit of water deanodized my tailcap in 5 minutes.
I'm pretty satisfied so far with the results - it really throws much further than all my other lights! However, it doesn't seem as bright as my other 1185 running in FiveMega's D26/G4 Sunlite socket. Maybe it is, but I'm not sure. I haven't really done a proper ceiling bounce test.
So there are 2 questions I have here:
1) I'm currently using Aluminum foil to bridge the gap between the tailcap and the cell's negative contact. I thought of changing to copper braid - would it make any noticeable difference over the alum foil?
2) The KD v3 SMO reflector has a pretty large bulb opening - 15mm to be exact. I'm concerned that I'm loosing light down here, or at least not getting it to throw as far as it could. I know that bigC didn't get any difference when using the 15mm reflector and smaller reflector openings in terms of lumens, but would it make my Mag throw further?
As 1) is much easier to deal with, I'm wondering about point 2) particularly because I'm probably going to be making an order from Litho for a couple bulbs, and he still has the .377" (~9mm) SMO reflectors available. However, if it's not really going to make much difference over the KD reflector, I wouldn't want to get it.
Does anyone here have both these reflectors - and do you see any noticeable change in beamshape/throw?
Thanks guys!
Edit: Some pics of the build so far:
Here's the Mag 2D along with my PVC battery tube (I used foam tape to wrap around):
With 3xIMR18500 installed (Waiting for the IMR26500):
KD v3 SMO Reflector & WA1185 bulb on Kiu socket. It's centered, although it doesn't look like it - because of the angle. As you can see, the reflector opening is pretty large:
Tailcap with copper wire:
Thanks guys!
