M2 Turbo options??
EO-6 wont fit in a Turbo head though.
The Turbo head lamps that will work in a KT1 on an M2 are:
Surefire N1 (on 2 x cr123a primaries)
Surefire MN15 (on 2x RCR123 3.6v Li-ion)
The lumens factory lamps that will fit the KT1 head are the HO-M3T and the EO-M3T, but these draw 2 and 2.4 amps, which is too high to run on two RCR123 3.6v cells.
If you want to run these lamps (or get better run time from your MN15) you'll need to add an A19 extender to you M2 and use either 3x cr123a primary cells or 2x 17500 li-ions).
All the LF M series and SF MN assemblies (LOLA and HOLA) will work in a KT1 TurboHead. It all depends on your power source.
This is not quite correct, Only the LF 'T' series and the HO-M4A and HO-M6R will work in a Turbo head, the HO-M3 and the EO-M3 wont fit.
Likewise the surefire MN10 and MN11 will not work in a Turbo head.
