M3 round bezel
mindstretch
British Columbia, Canada
Hi everyone,
Can a hex bezel be purchased from Surefire to replace the older rounder bezel on the Surefire M3?
Also, how water resistant or water proof is the M3 with the round bezel? Thanks.
Mindstretch
You can get it from Surefire direct. It used to be about $75 last year.
If you have a newer model with two o-rings at the tail end, it will be waterproof. It will not be depth-rated, but you can safaly take it to 15-20 ft.
Thanks for the info.
I guess it's an older model, it only has one o-ring at the tail end. Does the round bezel version have the shock isolation if it gets dropped or tossed around?
