M6 reliability
ADDICTED2LITE
arkansas
How reliable is the M6 with a LF-M6R and 6xIMP16340 cells in the MB20 carrier? What kind of runtime can I expect?
I also have a MN15 and 6 primary cells in a SC2 for a backup long running light. Is the MN15 a safe reliable option for a backup? How much runtime can I expect from this setup?
I primarily run a MN15 in my M6. It will give at least 2 hours of quality light with constant use. I have done this. Can't comment on the LF lamps with rechargables.
The MN15 is being overdriven over factory specs. But the setup is beautiful. One MN15 turned dark on me after 8 hours use so since then I break in a fresh set of batteries with the MN20 before I use the MN15, just to be safe.
The HO-M6R is a great bulb, and will work fine with the IMR16340s in the stock MB20 battery holder. You'll get about 25 mins run-time from 1 set of cells.
The MN15 is an excellent back-up, but as you have noted, it needs primaries rather than rechargeables in the MB20.
