well as long as you see the logic of what i am saying, that is all i am saying, when the overcharge state is reached the battery heats, and the voltage drops.
this effect is more visable when the battery was cold via the environment, but that doesnt nessisarily mean when the heat of the overcharge is removed from the battery.
a more sensitive Vdrop charger (like an adjustable one) or a high rate of charge, will still get the job done.
you see to my "simple" mind there is little different from any cell Boiling/bubbling at its end of charge, then the Vdrop which occurs when the pressure and heat rise in these thing. seems to me the vdrop is a result of internal damages beginning to occur.
look at the chart, its at 110-120% overcharge Already, its not Hey i am charged stop already, its Help me , i am dying here
its the same with lead acid, ni-?? and li-ion, they are all some metal plate with electrolyte battery. they all BUBBLE up when they reach overcharge (even if they dont show a easy vdrop). of course with li-ion pressure rise and heat is more critical to destruction of the battery.
