I had so much fun with the cheap and easy mod described in this thread that I decided to refine things a little bit. Keep in mind that in the true sprit of amateur modding, I stole liberally from those who did it first and added a little bit of my own.
This first picture shows my revved up Mag 2C. It uses a Radio Shack KPR112 krypton bulb. This bulb is spec'd at 6V and 650 mA. Nominally, it's a 5-cell bulb. In this case, powered by 3xCR123, it is significantly overdriven at around 7.2V. Below the body tube is the battery carrier I made. Based on kz1000s1's lead, I went to Home Depot and found a length of Bristoltherm CPVC Hot-Cold Water pipe. It is identified as 7/8" OD and 3/4" ID. I found that the ID is actually a bit smaller, perfectly fitting around a CR123. The OD is about 1/8" smaller than the ID of the Mag 2C body, but that's were a couple of layers of industrial grade duct tape come into play. I wrap just enough to create a perfect slide-in fit with the barrel to make it rattle-free.
Below the battery carrier are the three CR123s. Below that is my Neat-O, self adjusting fake battery slug. It consists of a variable length of 1/2" copper water pipe, two copper endcaps and a spring. I used a 1/2" x 1.5" x 0.41" compression spring also found at Home Depot. This little thing is nice on a couple of counts. 1) You can cut a different length of 1/2" copper piping depending on the specific blanking need, 2) different length compression springs are available for each application, 3) copper provides an excellent conduction pathway for the juice. There is an example of a longer length spring in front of the batteries.
This next picture shows the assembly of the Neat-O battery blanker. You just slide an endcap on the pipe, insert the spring, slide on the other endcap and install in the flashlight. The caps are just loose enough to allow the spring to seek its length. Alternatively, you could remove the stock Mag spring and use this to make up the space to the endcap. In this case, I would extend the battery carrier down into the endcap to provide stability to the battery stack.
The next picture shows my Mag 4C ready for its transformation. Going in will be 6xCR123 and a KPR144 bulb. This bulb is rated at 14.4 volts so it should be driven at spec. My guess is it will provide somewhere upwards of 150 lumens. I will probably try to get a 7th CR123 in there for some serious overdrive. The real fun will come when the Carley bulbs go in.
I am considering starting up a group buy for some Carley bulbs and adaptors. I am presently researching this and will be back in another thread to post options and troll for interest. Stay tuned for details. Thanks to Lemlux and Paul_W for the inspiration. I think that this kit, while not exotic or difficult to put together, will provide you with a 2C-form factor torch that will produce at least 14 times the light output of the stock configuration for under $50. That's 285 lumens of eye-sizzling fun. If you're interested in learning more about this monster mod, check out this thread.
Wilkey
restored 12/21/06
Wilkey
restored 12/21/06
