Thanks Nova!I found a couple of places that sell them here in AU, but they were fairly expensive. I don't remember the exact amount, but in the $18-$22 range I think, it is cheaper the get them from the US. You might want to try Batterystation, I think they have cheaper shipping. Lighthound also has them (US$10 last time I checked).
Cheers,
Nova
KiwiMark,I found the question confusing - what does 'or' mean?
Buy both! (I can't believe no one has said this yet)
Mag85 to 'wow' others.
ROP for a day to day useful flashlight.
The OP is looking at purchasing either of them used, which is generally cheaper than putting one together from new parts.Build a Mag Rop Low. Thats the best bang for your buck. Bright enough, and great runtime. Also, very very very cheappppp
1185 current draw is around ~3.2A compared to ~4.5A on the ROP. More than a little easier on li-ions, not to mention you won't be tripping the protection curcuit.
Wow, really?? This is the bulb I ran, but at 1300 lumens it would be right up their with the Mag85. In my experience the Mag85 was a big step up in output compared to the 3854-H ROP. Maybe someone who has both can do a quick comparison?
- 3854-H @ 7.5v : 4.5 amps, ~1300 lumens, max voltage 8.5v (therefore a 'whiter' beam @ 7.5v and probably less bulb life). ElectronGuru recommends this bulb for 6xNiMH, which from what I understand is a more appropriate choice for this slightly lower-voltage bulb.
:popcorn:
The ROP has a cammed reflector, which is a "must have" for me.
This is good info. Although I would never recommend running the 1185 on 1600mAH cells. I run it on AW 'C' 3300mAH cells for ~55 minutes of runtime. I would hope the overall output is greater and the gradual decline in output much less than with 17670 cells.I actually had the WA1185 in my Surefire M6 w/ 3 AW 17650 cells. MrGman tested it for me and I got this:
SF M6 Host, WA1185___,__3X_AW17670________Incandescent___1061.7,_____3 sec_______,
SF M6 Host, WA1185___,__3X_AW17670________Incandescent____973.8,____30 sec_______,
SF M6 Host, WA1185___,__3X_AW17670________Incandescent____917.8,____60 sec_______,
SF M6 Host, WA1185___,__3X_AW17670________Incandescent____878.5,___120 sec_______,
SF M6 Host, WA1185___,__3X_AW17670________Incandescent____880.4,___180 sec_______,
Build a Mag85 with AW 3-mode switch. Use a 3C Mag with 3xLi-ions. Then yes, you have a "wow" light, but you also have an extremely useful day to day flashlight. How does 60 minutes of runtime at 1300 lumens sound? Not to mention the runtime you will get at 30% and 60% of max... Need lower output for close or medium range use? - click the clicky to one of the lower levels.
ROP vs. Mag85? No contest - Mag85.
If you were going to buy/build youself a Mag mod, which would you go for?
