LilKevin715
A lot of us guestimate how much light is lost from the emitter to OTF for LED flashlights. I frequently see members posting a inconsistent percentage number of emitter vs OTF lumens (anywhere from 66 to 85 percent, depending on the type of lens & setup used). This is one of the very few topics here on CPF that hasn't been fully tested (to my knowledge). Recently I built a lightbox (details here) to measure realative output that can be used to calculate estimated lumens, which I call Lightbox Lumens (LBL for short). Since I now have the ability to measure relative output its time to do some definitive testing and put these claims to the test (and to satisfy my curiosity). This testing will determine light loss from components such as reflectors, the bezel, and lenses.
Test equipment:
Lightbox (duh)
LX1330B Light Meter (+/- 3% claimed accuracy)
Maglite XM-L T6 1D w/ 3-mode driver, 3.5A on high (details of the build can be found in the link of my sig)
Reflectors: Stock Plastic SMO, Kaidomain (KD) Aluminum SMO, KD Aluminum OP
Lenses: Stock Maglite lens, Hardcoat Acrylic lens, Borofloat lens, UCL lens
Testing Procedure/Overview:
Baseline:
First a baseline test needs to be performed so we can use it as a reference point later on when doing any comparisons and calculations. This first test will be to unscrew the Maglite head and measure the light output in "candle" mode. I chose to use the low mode on the driver (150ma) to minimize thermal related output sag. This ensures test results are consistent and repeatable due to the emitter not heating up too much. Measurements throughout the entire experiment are taken at 30s to match the ANSI FL-1 standard.
Reflectors:
After the baseline test is done reflector efficiency will then be measured. The bezel and lens will be removed from the head and the reflector will be inserted. The head will then be screwed onto the body tube without the bezel and lens attached. Each reflector will then be measured for light loss. Reflectors will be tested in the same position height relative to the emitter.
Bezel:
Same testing method as the reflectors except screwing on the bezel with no lens attached.
Lenses:
Each lens will be tested with the the three different reflectors, generating twelve test data results. The bezel will be attached for each test. Each lens was thoroughly cleaned before testing so there wasn't a spec of dust, smudges, etc. As a side note stock Maglite lenses are notorious for scratching/smudging easily and this can lead to reduced output. I used a brand new out of the package Maglite for the testing with a lens that had no marks at all. A scratched/dirty/used lens would obviously reduce output and wouldn't be a fair comparison.
Testing Results:
The units in the table are given in both Lux values measured by my light meter as well as LBL values. There is a small difference in the Lux vs LBL percentages so I decided to include both for completeness.
Calculations:
Reflector Efficiency: Reflector without bezel and lens / baseline
Bezel Loss: Reflector Efficiency - (Reflector with bezel and no lens / candle mode)
Lens Efficiency: Reflector with bezel and lens / Reflector with bezel and no lens
OTF: Reflector with lens and bezel / baseline
Here is a slightly larger image for easier viewing (click to enlarge)
Test equipment:
Lightbox (duh)
Baseline:
Reflectors:
Bezel:
Lenses:
Testing Results:
Calculations:
