mag's standard reflector: Cree or SSC?
Definitely the SSC, the Cree's beam pattern is too narrow to be used very effectively with a standard mag reflector, very ringy. If you go to a MOP reflector it works out pretty well.
Here are beamshots from a standard M@G reflector with an XR-E and a Seoul P4. The pic's have been desaturated so that the beam pattern is more obvious.
Seoul USVOI and XR-E P4, but different drivers so not an indication of relative brightness.
Colin.
Give the reflector a quick swirling pass of Clear Krylon spraypaint and say goodbye to the rings of Cree or the standard Mag Bulb.
Keep your distance 1-2 feet and give it 2 seconds spray at most.
Thanks guys, how deep is the LED sits inside the reflector to get a sharp focus? any image would also help :)
The base the emitter is mounted to is just below the bottom edge of the reflective potion of the reflector.
