ProofTech
Recently, I've noticed that when my Maha C801D charger is plugged in to my small APC uninterruptible power supply and charging a bunch of Eneloop AAs from the same flashlight, some of the cells will finish at a decent temperature, but the other cells will finish 10-20 minutes later and at a much higher temperature (too hot to hold for 10 seconds). BTW, the UPS is not running on its own battery while this is happening. When the charger is not plugged in to a UPS, all of the cells will finish at about the same time and none will be hot. Has anyone else experienced this same phenomena?
ProofTech
ProofTech
