Maha/LaCrosse-like Li-Ion charger
jch79
**Do Not Feed The Vegan**,
On the asphalt.
I've been trying to find out here why there isn't a battery charger similar to the MH-C9000 or the BC-900 that can test mAh through a discharge or test cycle... am I missing something, or is this sort of technology not possible?
I'm thinking your average R123/RCR2, and then 17670/18650's... all 3.6 volt.
Thoughts? And my apologies for any battery charging newbiness showing through...
:) john
DynoMoHum said:
Duratrax ICE will do it... or at least it will do a discharge test, and I'm 98% sure it will cycle as well... Find them at hobby retailers... You'll need a 12 volt power source for it...
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHDJ1&P=ML
Thanks for the link...
This is strange - there's no turnkey solution that isn't as large and requires an external power source?
Li-ion do not need to be cycled.Packs do need balancing from time to time,but other than that charging is very simple cc/cv to 4.2 v . My triton will do a discharge and report capacity but won't cycle. maybe a safety issue. imvho
C
C
Thanks Christoph - like I said above, my main interest is in accurately reporting the mAh capacity.
The triton looks like what I'm looking for... I think! :shrug:
:) john
