...I am the proud owner of a brand new MH-C9000 and am having problems understanding the settings.
My main question at the moment is when putting cells in for Refresh and analyze there are 2 settings and I am not sure if I am setting them correctly based on the manual.
First setting is charge rate. (please set me straight if I am reading this all wrong) I have a 2200Mah x .5 = 1100 manual say between .3 and 1.0) for my charge setting...
The Industry Recommended Charge Rate is 0.5-1.0C. Thus, for 2200mAh cells that's 1100-2200mA. IMHO, most
Newbies 'overthink' things and then get nervous looking for 'Hard-and-Fast' Rules. Instead, look for GUIDELINES, experiment, and then choose what works best for you / you like.
Personally, before I found CPF, I often charged at 200mA (with my La Crosse BC-900) and did quite a bit of damage to my rechargeable battery collection (i.e. unrealized missed terminations on ~50+ Rayovac 1300mAh and/or 1600mAh HSD NiMH cells). Before the BC-900, I used a Rayovac PS1 (~200mA) and then a Rayovac PS3 (~500mA). Since the PS3 got my cells pretty hot and the PS1 didn't, I (incorrectly) chose 200mA for the BC-900. Now, with my Maha MH-C9000 and it's wider channel spacing, I charge my 'newer' LSD and 'older non-CRAP' HSD cells at as high a rate as possible between 0.5 and 1.0C without generating excess heat (measured 'somewhat inaccurately' with an old RadioShack Indoor/Outdoor Thermometer - i.e. if 1.0C gets the cell over 120°F, next time I'll lower it to 0.75-0.80C and monitor the temperature again).
CLICK on my Sig Line LINK and you find PLENTY of 'Charge Rate' articles in the first section '
Rechargeable Battery'.
...and I am leaving discharge rate at default. Am I getting it right or should I charge at a higher or lower rate ?
For Discharge Rate, I always use 0.2C for '
Standardization', i.e., when you run a 'Break-In' cycle on the MH-C9000, it charges at 0.1C and discharges at 0.2C. Since I record those numbers, I like to also compare 'Apples-to-Apples' when I run a 'Refresh-and-Analyze' or 'Cycle' cycle.
My observations show:
- LOW Discharge Current -> HIGH(er) Cell Capacity
- HIGH Discharge Current -> LOW(er) Cell Capacity
Again, not a 'Hard-and-Fast' Rule - just a choice I made.
You made a good purchase. Invest a few hours 'Reading-and-Learning' about proper 'Care and Maintenance' and then have fun!
