00tec-satx
- Joined
- Feb 18, 2010
- Messages
- 2
Newb here, so please be gentle :wave:
I am going to mount 2 rebel leds behind lenses (the Rebels pre-mounted on 10mm aluminum squares-- 180lm cool white). Seen here:
http://www.luxeonstar.com/premounted-rebel-cool-white-led-on-a-10mm-square-base-180-lm-p-575.php
I will be building a simple regulator using something along the lines of a LM317t adjustable regulator, but would like the ability to use a push button dimmer to switch the regulator up/down so I don't have to have the LEDs wide open all the time. They will be flush mounted under the hood (with adequate ventilation). I have experience with the regulator, but never had any projects with a transistorized switch. Could someone point me in the right direction?
Bright/Dim would be cool or even Bright/Dim/Off...
Thanks in advance,
Michael
Thanks in advance,
Michael
