Malkoff 3D on Eneloops?
RayG
After lurking around here a bit, this is my first post. Let me begin by saying - the amount of information on this forum is staggering. Thanks!
Today at Costco, I picked up a set of Eneloops with charger, and it came with C and D adapters. My question is: Can you safely run a Malkoff 3D mag drop in on three of the eneloops using the adapters without damaging the batteries? If yes, what sort of runtime would they give?
assuming the eneloops are aa's, yes it would work, with a stock dropin, the runtime would be about 3 or 4 hours
By stock dropin I assume he means the MagLED. A malkoff would get significantly less runtime. An eneloop has about 1/4 to 1/6 the capacity of a D cell (alkaline/nimh) so with Gene's stated output of 6 hours on 3d's you should get about 1 hour on the 1AA to D converters.
1) yes, it is 100% safe: I do this all the time (in fact, I use something much wimpier: Enerjunk D's, which are are AA NiMH's in a D jacket).
2) AA eneloops will give you 1/10 the runtime over generic D alkys. (Eneloops are 2000mAH = 2AH; D alkys are 20AH)
