Sold/Expired Malkoff MDC with M361 219B, Nitecore TM15, Malkoff MD1 with TorchLab v5
TyTEK
Doing some spring cleaning and decided to post these items I don't use.
PayPal G&S only, no trades please. I ship within the USA via USPS priority with tracking.
No batteries included. These are cross posted.
1) Malkoff MDC body (1x123) with a VME head
and Illumination Supply M361 Nichia 219B V2 light engine (3.4V to 6V input).
This one has been carried a few times, no scratches, or dents. Very little actual use. Beautiful tint, I believe the LED specs are very similar to the V3 drop-in: 4000K, 95 CRI, with three modes: 10 lumen / 70 lumen / 330 lumen
$135 to your door (sold to Renthall)
2) Nitecore TM15 Neutral White
This guy is basically brand new as well. It's been taken out of the box to test, but it's just sat in my flashlight drawer for years. I've got a TM26 that I use all the time, so this one never gets any love. XM-L U2 emitters, not sure what the color temperature is, but it's definitely on the warmer side compared to my TM26.
$140 > $120 to your door
3) Malkoff MD1 modification with an Oveready DPC clicky tailcap, custom heatsink and retaining ring, and TorchLAB v5 Triple P60 drop in.
The body was cut down from a larger Malkoff tube and re-threaded by Martin White on CPF. He also made the custom ring and heat sink shroud for the v5 drop in. These parts have only been assembled by me and power tested, but never used or carried.
Notes: The drop in specs are XP-L Hi 4200K primaries with a Red (640nm) secondary. Drop in is rated for 32W and 3500 lumen. This thing is a little bit chunkier than an Oveready B.O.S.S. and functions just like one too, optical programming and all.
With the Malkoff head and custom heat sink, I've been able to run this exact setup on the highest levels for quite a bit longer than a B.O.S.S. flashlight at similar settings before thermal regulation kicks in, just because of the additional aluminum mass. Plus, if you've already got other Malkoff bodies, the drop in can be used with them as well.
This body will accept 18350 batteries. You will need a high current drain IMR battery to run the v5 drop in at higher brightness levels. I have been using the Keeppower IMR18350 1200mAh High Discharge Flat Top with this exact engine with good success.
$400 >$370 > withdrawn
Malkoff MDC with VME
yjNIyu7DIUjs9aHZkXYHhYZn6EnZ1uZ2bDUSvn_2Bxxm6sUM9i43ttBgwiSEvICILVUKrDKZ2UvpUOcNV6TvJuNz_mTCmgl_gtnh7siHGyChxGmc-PxssTqFRlYSxghwcVwBGjtZBQ=w2400
oWWVlKBwonD4-uz_INFVlyWWMhzh8MkfbkEXfF8wnM7YrApMxQ9lH-etlgJVfwf8dj5fGv-zeuYOAmsdc4207IfxzmkizcD2Msj8fIEjgpAa0HKba3ETOR_oKPvkMOfpeirXIi2AHA=w2400
uECxqN2-qbI6FqbIn9gWSVAI6ymTIHOQiIWAu_crxObvgz8dWsPlI7GAKU1Q8A6L8rpAq4EPT1CAT49yZ9iYteAcvl1BKiz4McQ6MT6-_67nF1oGPm6ojRqap3PBXLMdRB2R7znO-g=w2400
Nitecore TM15
yFTrovYJYc1QFRcEvfcyxAgVL0gSBZW9OwNcILUDW8Q_Ivk2pitX0USukDBI99pVvvcwTewOg7eko49MOtiO_KZ1m7TPDbMRvd3sXoIP1peb4AKHg7vUL1BBxEIfrUfGnsRBd3HLhg=w2400
l1esNOy4sglhsENhDrLuN7Q4BIHQRak3M0CUN4s5_JFfp97fmYdjLryS6CdxlvdBzbQaB-Wvh-GD8I2u1Fm8gMef1c4ooweYm_Ndx7tXNF11wAjFWQjYyAiFHQaqUo2UzvHdpZRH5A=w2400
YUWUNx3XXkRswXPlrATv2SnxXqOinou3RCRgH2qKWN0AUfVN0nixl1Vo4Jh9h76AY86WbLicYkExvyLf-eBz4GQbT8CjGAjOHPM6FIZzZaZBB_rPJern-DdRUJxNCzQ848JrFGPBfA=w2400
lqVvym3ty_PThkxQ2Ox0TpRaQETokW-wF-PLVuOLFJlFZqJqOtRM1giirQ76jBwdEjEu5COOnBBI6OLnUK0GhewDqTUtr51wqxUt0DFp_vgTINH8VRxZLPyBjakcm6Xw-80QXHfFKA=w2400
zlsFCtIuHcWm1DJW_LfNgrglnQ_1fL6veJ-FpPCL73JTroRSMP93xCnIt4pk4WZ7bwjlb6Iodd39O8y4umk3qkE-IqilxLy0rGKRJQiNEOm2IfI2I5yIlyn8fnrDCqVbuwcO2nyGaA=w2400
5bhnx80uUIgpxYTbMb4RxhOp5gJ4TQQiEAadDlASgOMuZlGlLffE8CEcYip_Uib4FTtohS5dgSz97-OZjv9vKj_z29UiZgTwTvGbXPk07uPZkxoriT0MH4i0G6NQUlj_OFgh3WZiSg=w2400
Z0mQiHC_Ayo7XkMd7VeeIHvNbC9CJd4x5OdI_Kxp0IxQey-XuaQKTJxi03qOST2wElXAg12Lj0nBNy9AD76gk98gt5zlHWHVt2CURvbs5RubgPbgbNKEoVrzkqxbKpjmYeOQvDfWZg=w2400
Malkoff MD1 with TorchLAB v5 drop in
g3zdWGo2lldn7DPmNBQEHh4YWSnf5p2_UgZRyTVsgsA-9Z1B_mpkgoO415vygjTUswW8CigGLwLWeAa-4AvLmoxPZGQZk3W0z7zhj398MoW_qOdXk4gs0klgR3SZQp7Fe66iw21hCA=w2400
KlnQQp8bN1JJkZljjQ1lLFhjG59Lff77XpCHAOm3Ye5VhK_oouU9B7CwclRPaZh4rAXllbN_RdAd_75D8wDUK0MG8glRT-qmSO6OTb1Rgpwat1UPb2wnMLcCVP7-2OHLTjf01FSI0Q=w2400
N6FLPS0fSkCl1U6d5F5VavZ7CSw9xaf1ozrQer4_oCGeo50wjuR8BdKKZAw2gZk0FFQLbav56qdLSMg02G2s8gESBqB4b05WvYpvLZZZOos0hWXup62N1sZUH2pq_pRUDiy3t4Awfw=w2400
KTGW4XoVzzf5l7ZyYGvVn_wqvvfWimm2FOrQG_ybVMUS1b-ldkZoSm-us5DpOz59oYVjhsIRKr308JOi9e8aV7bpqtd8Go16_Cm9aLsTLH-o2_1AYOn1_9O9D_EXUj2iYLx1cqp1wA=w2400
XPr1NWugOH60CuJ7v-7j7HV2pYdpeZ6ejOJtH2gqpnzT0IYFi0pNZBHRhvsoOlR5DVkb9mfiekpN-oBujXW1qC5ebP5F26gTzQ5klLAfA2yUE95iy2Vrhfb-bizbL60R0usXk-LOBA=w2400
lYnKBa1A2NpTbuDyIXsHNvsEJcO95vf2f7HyIm_Rtc7ju-E-eo4FjmCkmgnlj54qC6BQJONrzYefSD3Kpo7u-X2FOsT3ZjXM_Yk5ytzWP23hjvui5omD2-UNL1pe_8GD_CfXMgWWlQ=w2400
Re: Malkoff MDC with M361 219B and Nitecore TM15
@Renthall, sent you a PM, thanks!
