Fallingwater
I want to buy four of these, with the intention of using them in a model drill (Dremel lookalike) to make it cordless. I haven't yet decided if I'll use three or four cells (the drill is rated at 7 to 18 volts).
The drill draws about an amp when spinning but not being used for anything, but the draw increases considerably when it has some resistance (such as when using a cutting disk). I need the cells to endure draws up to two and possibly even three amps.
I know 1C or slightly higher discharge is fine for the cells themselves, but I'm not sure if the protection circuitry will allow it.
