Hello,
I'm planning to replace the stock LED in my Sigma PowerLED bike light with a Cree MC-E. I've come up with this tentative controller schematic based on a BuckPuck driver and the Picaxe microprocessor - which is the only such IC I can figure out how to program:
http://picasaweb.google.co.uk/ulrik...rsion?authkey=TnQPTJ5-nrI#5258585140467052290
Not being an electronics wizard I'd appreciate some input on whether this circuit is likely to work in real life - before I start inadvertedly toasting silicon. I have two questions in particular:
1. U1, Q1 and nearby components are supposed to latch the circuit in an off position once battery voltage drops below the cut-off for U1 (app. 4.3V; below this voltage the control signal from the Picaxe cannot fully dim the BuckPuck). Do you see any reason why this might not work?
2. Q2-Q4 are supposed to switch the MC-E LED configuration from 2 parallel chains of 2 dies in series (2S2P) to 2 dies in parallel (2P) when battery voltage drops below a point where 2P should theoretically (based on the MC-E data sheet) produce more light than 2S2P, or when battery voltage is simply too low to drive two LED dies in series. Again, do you see any reason why this might not work?
I realize that there could be many other approaches to this. My main aim in this project is to get more lumens while retaining or even increasing the light's versatility with respect to the kinds of batteries I've already got (6V and 12V NiHms), that are readily available for purchase here (AA alkalines) or that I'm planning to get (a 14.8V Li-ion). I've ordered MC-E specific lenses and am confident the cold climate where I live will be enough to keep heat management issues in check.
Once I get this working, I'll be happy to share the finished design, including the Picaxe software. For now, I just hope some of you wise people can help me evaluate the circuitry.
Thanks,
Thanks,
